Roadkill check and see if you have a running/turn signal bulb out or loose. That will do what you describe. If not then do you know how to read your fault codes? Ted
well hopeful the problem is fixed better half had to get me the new chrome light for the back of the tri and they where led so they need a load equalizer put in the line because led don't use the same amperage as standerd bulbs so hope fully that key will stay off know
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
