Has anyone put on the screaming eagle pipes and if so good sound and do you like them? thanks
I'm looking for something louder than whats the stock set-up. Just to quiet for me !
If your still running the factory head pipe with the catalytic converter you could perk up the exhaust note with the Screamin Eagle Thunder Street Performance slip ons PN 65115-10. These mufflers are the exact mufflers Harley used to sell up until late 2005, off the top of my head I believe the old PN was 65115-98b. At the time they were labeled for off road use only. Now with the introduction of the catalytic converter HD was able to bring them back for use on 2010 and later touring, they are 50 state legal with the 2010 and later exhaust.
If you remove the catalytic converter or install a Fuel Moto Jackpot head pipe or one of Fullsac's pipes they will be much louder, I believe they were right around 93db with a non catalytic converter head pipe.
I have these on mine with the vance and hines power duals, they sound good. The HD web site say they do not fit the trike or CVO models, but they do. They sound good without the Cat in the headpipe.
The H-D Fatshotz(made by Supertrap) are a little louder then stock, but mellower. No where near as loud as Rhineharts.
Cruising down the highway they sound like what a motorcycle should sound like......in my opinion
Someone from the AMA came to our HOG meeting last month and had a sound meter with him. He checked all the bikes that wanted a check up. Mine was under the limit so I feel OK riding anywhere in the country and not worrying if I'll get ticketed. :Coffee:
I would recommend the H-D Fatshotz slip ons. Great mellow sound and not offensive.
Here you go Skeet,
These are the Fatshotz but I installed the closed end caps and added extra discs to mine. It was a kit I purchased from Supertrapp. The medallions were added to cover the holes made when my old bike was dyno'd. They had to drill holes in the end caps for the sniffer. I like the end caps, keeps the noise down, my ears can't take too much any more.
Delta, your mufflers are FatshotZ and you did change the end caps and add disc right? But can't you do this to the Supertrapps also?
Which muffler will be more mellower, and not loud.
