Sand Blaster
I've got a pressurized blaster. Works ok, the compressor has to be large, takes a large volume of air. If the pressure falls off doesn't work to good. If you only do small stuff its ok. Other draw back needs dry air. I have a motorcycle frame that needs blasting I'm looking to hire it out. Its not worth the time and effort. If you're gonna sandblast you must wear a mask don't do it with out one!
El Cabron
