For the owners installing mechanical reverse gear, what do you do with stock reverse set up ? Thinking of installing reverse on my 11 tri glide, just wondering what to do with stock parts.
For the owners installing mechanical reverse gear, what do you do with stock reverse set up ? Thinking of installing reverse on my 11 tri glide, just wondering what to do with stock parts.![]()
If you remove the reverse motor , don't you have a way for water and dirt to get somewhere they shouldn't be?
If the motor can be removed without problems , I'd like to know as I'm all "the ballast" the trike needs.
Thanks Rhino2. If nothing is getting into the primary case then off it comes.
You could make a template and cut a piece of tin, make a gasket and bolt it over the hole the motor occupied. That could help debris getting into the sprocket area
Mine went out Saturday when I was leaving to drop my Trike off at the Indie shop for a handlebar swap. I didn't think much about it as it was cold. Some things just don't like to work right sometimes when it's cold. I picked it up today and still no reverse and it was warm today. I checked the breaker and it was tripped. Reset it and still no joy. I've looked at the mechanical reverse but don't think I want to spend that much money. I've probably used it a handful of times since I got it in Sept. so I don't think I'll really miss it. I usually push it out of the garage in the mornings to go to work (4am) anyways.
Took it by the dealer on the way home and they tried to blame it on the bar swap so won't cover it under my ESA. I guess I should've waited on the bars and had it fixed first. Oh well.
Brian I think you may need to push a little harder with the dealer on not standing behind the ESP. The changing of the handle bars would have been a very remote cause of the reverse not working. So the fact that you waited should of had no bearing. I think need to make them prove to you that it was the cause.
or find a new dealer
I'm looking at the MT mechanical reverse. I talked to the same shop that did my bars and they quoted $2100 for the kit, install and 3 hole fluid change ($1500 for the kit and $600 for install and fluid/filter change). That doesn't sound too bad does it?
As long thats also including the reverse Cut -Off wire harness.....That harness will shut the engine off immediately with NO damage to the Transmission if you are in Reverse and forget to take it out of reverse and hit first gear.....And sometimes you will forget...I know i have a few times...:blush:...
sounds very reasonable
After looking over many of the threads here about the mechanical reverse, I think MT should pay @rhino 2 for all of his advertising and recommendations. LOL.
This forum has been a great help. Water pump went out this morning. I called another dealer other than where I bought the trike. They have the upgraded kit in stock. Here's the great part, they are going to come and pick it up and bring it back after it's fixed and will replace the reverse motor if they have one in stock, all under my warranty/SA. No questions asked. Y'all have talked about different dealerships giving different service and damn if it ain't so. Lol. I didn't even ask about them picking it up either. They offered. They will pick it up about lunch time and then schedule when to bring it back after they are done. That's some good service right there.
Still installing the MT mechanical reverse though. It's already ordered and I don't have to worry about the electric one going out again.
Do it........Just be careful backing out, Its not like the electric you can fly out of a parking space, You'll love it you will never have to pass up a spot you can park anywhere like a car..:clapping:..
