Reverse problems
Sep 7, 2016
3
3
Fresno,Ca USA
I have never used my reverse. Tried to use it the other day. Put bike in neutral pushed the reverse button no reverse lite, tried again reverse motor engage but did not engage flywheel. Anybody have this problem?
If the motor works, it sounds like the bendix gear is not sliding to engage. Try some penitrating spray then work it. Need to use it once n a while, or switch to mechanical type and forgetaboutit :D
Do a Search on the reverse motor.....Theres enough info on that to keep you busy for quite awhile...:(......
​Order a mechanical from Papa Zook and forget about all the electrical problems. Installation is fairly easy and when you put it in reverse you know it will back up. One of the best things I've done to mine
jkittoe48
