Will this work with each signal light??? View attachment 94257-SYLVANIA - Load Equalizer 27 Watt (at 12.8V) - Turn Signal Load Equalizer for LED Light Bulbs, Corrects Hyper Flash & Bulb Out Warning.
That should workYou should need 1 for each circuit IE 1 for front and rear turn signals and 1 for running lights, same for brake lights
Led lights use low voltage. You will need a load equalizer to make them work.
Look here https://www.amazon.com/SYLVANIA-Equ...er+for+led+turn+signals&qid=1608609126&sr=8-3
actually in his case they are working on 12 volts but because the amps are lo the flasher doesnt work
Thank you, I stand correctedShould we change amps for watts?
View attachment 94425-I love it when Happy Hour is all day...:clapping:
View attachment 94557This was my garage before the move of 2018, Finishing up on the "Trikester" and much mock up on the "RebelRouser"... "HAPPY NEW YEAR EVERYONE"...
View attachment 95322M/C return spring works, bleed the brakes many times but just not quite there??? But it does work...![]()
