rear brakes
wlivin2
400+ Posts
Feb 22, 2020
497
482
Washington, PA
Wayne
I have a 2010 thi glide ultra the travel on rear brake is very long bike only has 9500 miles.
do I need to bleed them or adjust them or both bike was sitting for 6 months it does feel a little bit better after 150 miles of riding but not right .
Wayne I would check the rear pad wear. If the travel on the peddle is long but when it engages it is not sponge feeling then thats what I would suspect. The rear brakes on the 10 where weak at best. And 10k the stock pads I bet are worn. If you but new pads in I would suggest that you use EBC brand pads. Search the forum for other posts about the pads for the TRI.
tstthomas
