Well heres an update on the brake conversion.
After making a bracket to hold the bias valve under the frame member which resides under the seat, i ran my russel braided lines to a new tee below the valve and attached it to the same bolt that holds the original tee. i then ran new lines to both calipres on the rear and tied the old lines in place so they could be reattached if i sell her in the future.
The line coming in from the front is stainless russell 54" long and it goes neatly under the taks on the left side. it ties into the new front tee which has a line going to the front left caliper and then up to the master cylinder.
The right front caliper is capped off.
After bleeding the system i set the bike in gear and got her wheels spinning pretty good up on the stands. after dialing in about 3/4 rear bias with remaing 1/4 to front i took her down and ran her down the road in front of the house, the results are better than i ever would have expected.
The lever activats with about 1/2" travel and the feel is no differnt than the stock front setup. If you choose to clamp down hold on tight because the wheels will STOP! :yes:
I have no doubt i could achieve a lockup with more bias toward the rear, but i am quite happy with what i have.
i appreciate all the help here and if anyone want a parts breakdown for their own conversion e-mail me and i will help. Thanks for the ideas and help 1550vt
regards, Roger
regards, Roger
