Had to park on a steep incline recently. Put trike in gear and used rotor lock for
insurance. Trike never budged. Whew!
Parking Brake stuff....many of us simply use a bungee-cord, or large rubber band over the front brake lever, or foot brake pedal. This seems rather like a "rigging", but it is simple and really does work. Of course....it's for those times that it is really required, Certainly....nobody would plan to leave one on for weeks at a time. Just pay attention to how you park and those times a brake is needed....this simple solution will work every time.
More talk about a line-lock then. The mechanical version can be had rather cheaply, but you have to pick a place to mount it in series with the rear brake line. All you do is apply the rear brake, set the line-lock and it locks both rear calipers (or one if that's all you have on some single disc kits).
A short line from the rear T is ran to the device, then the other side of the device is connected to the master cylinder. Just press the brake pedal, push the lever down on the line-lock. Then, you simply push the lever again to release the line-lock. Just requires a few fittings and maybe new hoses to connect and of course, the rear brakes will have to be re-bled. The only real problem is finding a location on the frame that is as low (or lower) as the master cylinder to mount the lock, or you will possibly get fluid drain-back into the master cylinder and wind-up with some air or void in the line. Ingenuity will prevail and one can find a way to do this. It could even possibly be mounted under the kit on the frame at some point. It doesn't have to be visible...only "reachable" so the operator can push the button/lever. And....as someone mentioned above, you can get an electrically operated lock with a solenoid, but this would require power to the solenoid to keep it locked. I would prefer the manual type.
It's just a simple (to many) brake-line plumbing job like the drag racers use.
When getting service yesterday the service manager told me the squeaking would not stop. He said he could not tell how many rotors he had replaced. He told me to call Harley customer relations and report it. They will give me a reference number, and that a recall was coming down the line. There is also a recall for the trunk latch.
