RAM mount on dashboard
Nov 25, 2010
531
16
La Grange, KY
Konrad
I've been thinking about mounting a RAM ball on the dashboard directly over the central speedometer of my 2006 GL1800, for the purpose of holding a GPS.
1. Has anyone done this?
2. Do you think the dashboard is strong enough to hold the mount? (with a lightweight Garmin 1390T.)
3. How would you do it?
4. Or is it a bad idea?
TIA for all advice!
I had thought about doing the same with my 82 GL1100 but had concerns about vibration cracking the ABS dashboard. This was even after considering using diamond-plate on the backside of the dashto increase the rigidity and sturdiness of the mount. I ended up buying a waterproof GPS case ($22.00) that mounts on the handlebar and am very satified with the results.
Snarley had a RAM ball mount on the handlebar when I bought her. I have camera and cupholder that can attach to it. I don't use it often, but am happy that it is there. Have used their fishing rod holders, and quality is outstanding.
The GPS is quite lightweight. And ABS is tough stuff. Do you really think its vibrations could crack an ABS dashboard?
I have RAM mounts on each handlebar but want to get the GPS centrally mounted and higher. The built-in Honda GPS is somewhat disappointing in useability.
Konrad,
I've tried mounting my Zumo 550 on handlebars, but did not like it. Look at the new location that I really like. IMO, it's not only easily accessible, but looks the best. Hope it helps:
TIA for all advice!
I have seen the ABS crack over time .. Best mount for GPS is on right handlebar using the hand brake mounting nuts .. Works great .. Run your power wired down the inside of the handlebar and then hook it up to a switched power source ..
I bought my mount from RAM, and it is actually for the dash of a small airplane. It fits great on the dash of my 1800, and I made up small pieces of metal strips where the mounting screws tighten down, so as not to damage the dash. Works great !
I am VERY interested in seeing your setup! Could you please snap and post a picture or two? Thanks.
craneop63
