problem with primary chain adjuster
May 8, 2011
755
25
Peru, IN
Leon
triGlide has 37k. on it .anyone having problems with OEM primary chain adjuster? whats the best manual adjuster. installed a new bolt in the screaming eagle compensator which had a shoulder on the bolt that the old one didn't have.
1.59 from dealer. it had blue locktight on it. so i put 2 drops of red on the inside of the blue; and torqued it to 170 ft. lbs.
just bought a open box with no instructions
need install instructions for DRAG solid sprocket compensator
p/ 1120-0390 vn 191200
started the bike up ad the p/ chain flops wildly. just over 3/4" slack. it was 1/4" when i removed the primary cover.thanks leon
chain afjuster
installed Drags compensator and a manual primary chain adjuster. 2009 trGlide
still pretty noisey, but haven't driven it only 5 miles so far. need at least 100 miles and its suppose to quieten down
Check Baker Drivetrain for a primary adjuster.:D:D
Your chain all stretched out and your maxed out on your adjuster?:confused:
Is the block worn out? :confused:
How many teeth were on the compensator versus new?? :confused:
dhinzman1
