PRIMARY OIL COMPARE
I have used Quicksilver 20/50 motorcycle oil and gear oil ( in the tranny) and liked it, I have also run the oil in my primary on my 15 and 17 Freewheelers
I have not used a Quicksilver specific primary lube tho
Maybe I read this wrong, if u are asking about using Quicksilver 20-50 oil in the primary, the answer is yes I have
It worked good, and held up good also, the hydraulic clutch seemed to like it
Quicksilver Primary oil. Thanks Jack, I guess none have tried that.
I dumped what ever my 21 Freewheeler came with from the factory and put the Quicksilver 20-50 in for 1k miles, I use it in my pressure washer also
It is a very good synthetic oil, I have used it since 2007 in 3 bikes and trikes
Well Jack, I am always leery of engine oil (20-50) in Primary or Tranny. SO I ordered a qt of Quicksilver Primary for next change . It will be a couple months before the change.
All the products mentioned can be compared by downloading the safety data sheet. I havnt because I dont care. But if one does they will see there's no magic elixir or ingredient except for the claims made by whoever is hawking it. A safe bet is to always choose the oil with the best looking lass in the advert.If shes using it you know its gotta be good.
Yep if Jennifer Anderson was to recommend using her shampoo in my Harleys engine then that’s good enough for me ….”With” the caveat that she has to come over and show me how to change my oil…
True fact
wzejda
