pre-load with Roadsmith Kit
Jul 8, 2010
36
Montevideo, MN
I have a 2005 GL1800 with a Roadsmith Kit installed on it. My question is, when I activate the up and down functions of the pre-load system, I hear a electric motor noise very faintly and the numbers increase and decrease on the display. I do not notice any difference in the ride or the physical appearence of the Trike. Do they dis-connect the pre-load system when they install a Roadsmith Kit?<br />
<br />
Thanks for any advice on this subject.<br />
<br />
Lee
Sorry I don't know about Roadsmith,but on Pearl(1990GW/Motortrike) I can see her raise and lower.Also can feel the difference when riding.RIDE SAFE
Your preload is probably working. I do notice on mine the stop on the preload only travels about a quarter of an inch with preload set to 25. I only use my preload in heavy crosswinds, stabilizes the bike very well.
minnlee, i ride a 08 gw with Roadsmith installed dec. 2010. I have tried several different setting on the preload. I have read on TT that riding with the rear suppension a little stiffer that you can corner better and with less sway. I have found that to be true. the trike rides a bit stiffer, however the better handling characteristics out weighs the change in the ride. on the scale from 1 to 25 i set my at about 18, except when riding 2 up and compartments loaded, then I run at 21-22.<br />
Hope you find the right setting. RIDE SAFE! <br />
jt just sayin
<div class="bbcode_quote">
<div class="quote_container">
<div class="bbcode_postedby">
<img src="images/misc/quote_icon.png" alt="Quote" /> Originally Posted by <strong>jtilmon</strong>
<a href="showthread.php?p=74976#post74976" rel="nofollow"><img class="inlineimg" src="images/buttons/viewpost-right.png" alt="View Post" /></a>
</div>
<div class="message">minnlee, i ride a 08 gw with Roadsmith installed dec. 2010. I have tried several different setting on the preload. I have read on TT that riding with the rear suppension a little stiffer that you can corner better and with less sway. I have found that to be true. the trike rides a bit stiffer, however the better handling characteristics out weighs the change in the ride. on the scale from 1 to 25 i set my at about 18, except when riding 2 up and compartments loaded, then I run at 21-22.<br />
jt just sayin</div>
</div>
</div>
</div>Mind if I ask what you weigh? That would give us a point of reference.
<img src="images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" />
<img src="images/misc/quote_icon.png" alt="Quote" /> Originally Posted by <strong>minnleeboy</strong>
<a href="showthread.php?p=75079#post75079" rel="nofollow"><img class="inlineimg" src="images/buttons/viewpost-right.png" alt="View Post" /></a>
</div>
<div class="message">I weigh 165 LBS soakin' wet.<br />
<br />
Lee</div>
</div>
</div>
</div>I meant jtilmon's weight - trying to get a correlation between his weight and preload settings. <img src="images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" />
I went on the Trikeshop site and found out that the pre-load system with a Roadsmith conversion is an option. How can one tell if it indeed was installed when the first owner had the Bike converted?<br />
<br />
Lee
mudrock
