Hi ; I'm trying to find a cross reference # honda paint code 181Y 2006 gold wing titanium. dupont PPg or any other supplier. i thought honda used that paint on some of their autos any help would be welcome thanks..
Hope this helps
Honda Goldwing Paint
Have you tried to have it scanned, for color match, work great to get a real match.
Using color codes is sometimes not very close, won't work if you want it nearly perfect match.
Type gun ( brand ), distance you paint from object and air pressure makes a different too.
I'm not finding a two part system for Goldwing. Three stage is all I see. Base
Catalyst and Reducer and then you can make it four stage if you add in the accelerator (optional). Or were you only referring to the Stallion as a two stage paint?
Three stage
1) Base Coat
2) Metallic Coat or Candy Coat
3) Clear Coat
Two Stage
1) Base Coat
2) Clear Coat
Reducer or accelerator has nothing to do with stage. Just for mixing the paint to a thin enough solution to be sprayed and/or decrease time for drying purposes.
It is important to do a 80% coverage on first spray, wait 10-15 minutes and do a finish coat. Let finished base coat dry 10-15 minutes and then apply as many clear coats as you want. If you do your self dust in the air is your biggest enemy,
What color are you trying to paint?
