I'm pretty sure we're going to get an enclosed trailer for those long distance trips we would like to make and be able to ride the trike when we arrive. About 300 miles seems to be the limit for the Misses for a day and that would take a long time to go from where we live to destinations out west or up to see our kids in Illinois and Ohio.
We've been looking at different brands in our area but nothing seems to be wider than 6', a fit but only a few inches on either side, not the best scenario for sure. We found a place about 1/2 hour from us that makes them to your specs. We looked at a 7 x 10 v nose yesterday when we toured the factory, inside dimension is actually a bit over 12', that would leave about 2 1/2 feet extra room at the rear.
Equipment
The trailer will weigh around 1400#, plus another 1200 for the scoot for around 2600 total, the capacity on our SUV is 3500 so that should work out well, we're looking at a total cost of around $4100.00 - 4300.00 out the door. The company has been in business for 31 years and no complaints at BBB.
http://www.1expresstrailers.com/
I would appreciate any thoughts or suggestions anyone might have.
Equipment
- Single axle
Spring assist ramp door with flap
6' 5" interior
3/4" decking exterior grade, B/C finish (sealed underneath with oil base paint)
Side door
24" diamond plate stone guard
Spare tire mounted inside
2 - side vents
2- rear drop leg stabilizers
LED lighting
Trike wheel chock
6- recessed floor tie downs
2,000 lb tongue jack with sand pad/foot
Torsion drop axles - rubber/independent suspension
E-Z lube wheel bearings
15' radial tires
