On/Off switch and Kill switch protocol
Oct 3, 2018
179
160
Johnson City, TN
Rick
Just curious, when you turn the key to on, and then turn the kill switch down, is the fuel pump the only thing that is activating? The main question, do you need to wait until the fuel pump finishes starting up (couple of seconds) or can you start the engine as soon as you flip the switch down?
Do you leave the kill switch in the run position all of the time or do you turn the switch to off and the turn the key to off?
Does it matter, is it harmful to trike or electronics, or merely a personal preference?
Turning On the Ignition Switch also starts all electrical functions like; systems checks, hand controls, deactivates security system, and provides power to starter motor and water pump.
I do my best to follow the sequence in my owners manual.
To Start Engine
• Turn Ignition Switch to on position
• Press the bottom of the OFF/RUN Switch
• Press the Engine Start/Hazard Warning Switch to start engine
To Shut off Engine
• Press the top of the OFF/RUN Switch to shut off Engine
• Turn Ignition Switch to off position
There have been times I've shut down just by using the ignition switch and restarted using the same. No ill effects so far.
I Never used the kill switch......I just turn the key off and walk away, Been doing it that way forever without any ill effects...:Shrug:...
Probably not as critical on a trike as on a two wheeler but MSF teaches to stop motor with run/stop switch and then turn ignition switch off. By doing this both hands are still on handlebars and you have complete control of vehicle. Personally I think this is by far the better way and I always follow it.
This !
On all my Harley's I have never used the kill switch. I was always told it was more of a safety feature, therefore by never using it would not have any ill effects on the bike.
It still messes me up sometimes when I pick it up from a dealer and try to start it. The first thing I think is my battery is dead until I remember that switch.
Probably not quite the same.......But with all my two wheelers , [Except for some strange reasoning With My Harleys and My Victory]........When you put the kick stand down [Unless in neutral]...The engine will shut off just like a kill switch....And so my SOP was to stop/park in first drop the kick stand and walk away...
You never switched the ignition switch to OFF? The kill switch and kickstand switches shut the engine down - but not the electronics such as radio, dash display, etc...??
  • Like
Reactions: MDO
Seen many put kickstand down and not shut off ign. Also the same with the kill rocker switch. = One Dead Battery :gah:
I should have splained that better.....I did turn the key off....:blush:,,
With my Victory i made a invisible key and i never took it out of the bike..
Me too. That's what the manual says.....and I always put the gas cap on the seat during fill ups. :D
To Start Engine
To Shut off Engine
Me too.
Thanks for the replies. I learned from my MSF class to use both switches so that is what I have done. My neighbor who has ridden 2 wheelers only for the past 20 yrs only uses the "ignition" switch. I just wanted more opinions from other riders. Seems like it does not matter either way.
After reading through your replies, I better understand about using just one switch and it seems logical. But, so does using both as 1 more step in the safety chain.
One time (had just gotten the trike) I had the switch on and flipped the kill switch and immediately started the engine (while the fuel pump was still making it's noise) and he told not to ever do that - to allow time for the electronics etc to start. Now, I am not sure he knows all about the more involved electronic bikes but at the time I knew nothing.
So, my method, I turn on the switch, flip the kill switch and wait a few moments. During this wait, I do final adjustments, putting on gloves, disengaging the foot brake etc, just giving the trike time to do its thing before I start the engine.
Do you think it hurts to start the engine WHILE the fuel pump etc is starting up, or would it even actually start? I know that we are only talking a few seconds here, maybe 5 seconds. Just curious, in case I would need to make a quick get away in case I am being chased my zombies or such.
Again, thanks in advance for your replies.
I rarely use the kill switch, only if I want to shut it off while keeping both hands on the handlebars.
However, I never start the engine while the pump is still going. Not that I think it would cause any damage, but I'm not that quick. :)
Seriously, it is probably best practice to let the pressure fully build before starting.
I have always used the run switch
I think now with all the new electronics on board it is more important to let the computer go thru its start up diagnostics before starting the bike. ( I never attempt a start until I hear the fuel pump stop its prime) JMO
+1! I do it the same for the same reasons.
There have been instances of individuals who were attempting to park, but not using the run switch to shut the engine off. They inadvertently let go of the clutch with their left hand to turn off the ignition switch and their rides lunged forward......some situations ended fairly well....some not so well.:AGGHH:
  • Like
Reactions: MDO
Regarding waiting until the fuel pump finishes its initilazition before starting I have one question - do you do that on your cars? Most cars (if not all nowadays) have an electric fuel pump and even though you may not hear it I would think it performs similarly to the Harley's. And do motor police officers wait before starting? I doubt it. So as far as I can tell it doesn't hurt anything to wait but I've started mine plenty of time immediately and no problem. Honestly I don't think it matters.
My Indian doesn't have a key. Just a button to activate and start button. Need a fob or security number key. But I still rarely use the emergency power of switch. I just hit the same button to activate the thing. It's an on/off type button in place of physical key. I still feel the emergency power of switch is for emergencies. But if I hit the activation switch and forget to hit it again to power it off, it will power off anyway after a couple of minutes. That becomes aggravating at times when you are trying to do something new and reading the darn manual. But anyway, no red power off switch for me even though I don't have that physical key.
Jeanna5080
