2010 Triglide. Just replaced air temp gauge. Today was 85. Was on a 25 mile ride at between 70-80 mph in 6th gear. Oil temp was around 240. What does yours run at?
FLTR2008TRIKE, That makes sense and I'll a little relieved. I have a six row cooler now and I was thinking of going to a new 10 row cooler or even fan assisted cooler. Maybe that's not necessary.
same here,chked my temp today after about 40 miles.164 at oil tank so if it's reading 30+ than i'm about right.about 90 deg.ambient temp.called H-D yesterday and was told if i change the cooler to a jagg 10 row and have a problem due to oil my warrenty is void. :Shrug:
WOW!!! Those Tri Glides, run hot!!! My 93 HD Heritage Softail 3 wheel converstion, runs right around 200 degrees, and that is in Florida. It is NOT a stock Evo, I have the STD cases, S&S big bore kit, 585 S&S cam, S&S modified shorty G carb, with a 6 speed OD Baker. I do have a HD horizontal oil cooler mounted on the lower frame rails. Only other thing I can think of is, I use Mobil One full Syn. oil. I have checked my oil temp. with a thermal degree checker, and it is pretty much on. I would be very concerned with an expensive Tri Glide runing anything over 210....
The proof of burden is on Harley. You have to be willing to fight them to prove it though. I would like to know how the dealer figures a larger better cooling oil cooler is going to cause a issue with your oil?? Thats like them saying you have to buy your light bulbs from harley or you might damage your electrical system ..... The comical things some dealers tell people........LOL
how do you change the oil pump on a 103 harley Triglide 2011
What everyone has to remember is that your 2009, 10, 11, or 2012 Harley Tri-Glide FEELS and RUNS hotter than your old bike because it is 103 cdi, not 96, or 88 inches. ALL 2009 and above Turing bikes have a catalytic converter in the head pipe because YOUR Federal Government mandated it.
