bikerbillone
3000+ Posts
I might be doing something wrong here, as some GW guru told me. Changing oil is was always my practice to warm the oil to operating temp, then jack up the front to allow access, do the drain overnight, or several hours, then wrap it all up dumping in the 4 quarts, then ride. My guru said the machine must be level, or almost, so there is proper drain, or if not on level, almost a quart of oil remains in the engine, adding 4 quarts will make it almost 5 quarts in the engine. Yikes, that's not good. Getting that machine on level requires some doing, so my question is, simple oil change is turning out to be more complicated, comments please.....One last thing, in those years I used the simple method of jack up the front and drain, then dump 4, I never saw a blow by or overflow leak, so I'm really a bit confused about this simple procedure.
