Noisy diff
Mar 13, 2018
4
4
Unitedkingdom
Hi folks I have a 1982gl goldwing trike, it has a reliant back axle, the problem is when the trike is on the move thru the gears it pulls like a train but when coasting it sounds like trike is dragging a sack of spanners behind , any ideas would be most appresiated
welcome aboard dave. Ride safe. Someone will get on here and give you some idea I hope.
David, Welcome to Trike Talk Forum.
I will take the bait.
Do you have any leaks in the rear axle ?
Is the driveshaft tight and the u-joint good ?
Sounds like a u-joint problem in the U-K ???:Shrug:
Welcome to the forum from Pennsylvania. I feel sure you will get assistance with your problem noise. :good: Travel safe Fred
Welcome from the state of Missouri :cool:
Change the differential fluid to start & see if it's the same, better or worse!
Jlsander74
