need help
May 20, 2010
56
winchester, indiana
don't have time to go thru all posts so here it goes. i bought rinehart tru duals for my 2010 xxx trike, they don't work without a conversion 90.00. already spent a 1000.00 and they don't work. what else is there that BOLTS ON. the conversion was just two
more places to leak. thanks homer
ps: rinehart and j&p just found out today about the problem with trikes
goin to call my stealership in the morning and see if they have done this conversion. i just want to leave the hacksaw, welder, hammer and chisel in the tool box haha.
Check out the Rush True Duals here <a href="http://www.epiflex.com/" target="_blank">Rush Motorcycle Mufflers - Slip On Mufflers - Motorcycle Exhaust - Motorcycle Seats</a>. If you order this setup make sure you specify for the TG so you get the longer head pipe for the left side. Mine went on without any problems.
I just installed the V&H Dressers duels on a 2010 T.G. with their adapters.
no problems, just make sure when adjusting the adapters that you clear the swing arm,
the adapter gets a little close.
We will like the sound of the true duels.
Dan
yrral
