need help for selecting HD Anarchy wheels for 2015 triglide
Jun 27, 2015
92
20
kitchener
I have a 2015 triglide and I want to put chrome wheels on it. I like the Harley Anarchy mirror chrome ones. My trike as far as I know has 15" wheels on the back and 16" on the front. (pretty sure can"t get to bike)
When I use the build a bike feature in the HD website here is what it recommends:
18 inch front wheel with new tire
16 inch rear wheels (obviously I would need new 16 inch tires)
My questions are what happens to the speedo putting the big wheel on the front and how does it affect handling?
I suspect it is showing 16 inch rear wheels as the rear tire on the 2016 models must be larger than the 2015 models?
Any advice you can give?
I have the Anarchy wheels and new tires on my 2014 TG. No problems. I also asked my dealer that question and he said the speedometer is connected to something (wasn't paying attention after he said there was no problem) that didn't rely on the size of the wheel. :cxtv:
I don't think your wheels are any different then mine.
I use my OEM wheels/tires as my winter setup and switch to the Anarchy wheels/tires in April. ThumbUp :D
So you went with 16" in the rear and 18 inch on the front? Do you also have a comfort lift installed?
The speedo is read by a sensor under the starter that goes into the transmission. It reads a vane in there. The front wheel will not effect it. The diameter of the rear wheels will.
Bullet Proof
