Neck height?
Looks much better to me...closer to #38 which is a nice looking leading link.
Better have stacybg give his blessing on this one, he has the experience, and knows what works, and how to fix what doesen't.
Got back from a trip to South Dakota and Colorado on Sunday. Awesome time. Awesome scenery.
Been helping my GF's daughter paint her new house before she moves in. That sucks. I've been reminded for the last 3 days as to why I hate painting the inside of a house...lol. But it's her first house, and her dad is a pos, so I help out.
Will be back at the design phase and pulling wires from the 3.8L over the weekend. Good news is I had the motor turning over with a battery right before I left on the trip. Plans are to have it running on the makeshift stand before putting it in a frame. Then its a matter of extending/shortening wires as needed.
Looking forward to checking out everyone's projects and progress.
Thanks for everyone's input.
Steel for the trike and camper frames, and aluminum sheet for the fuel tank have been ordered for delivery Thursday.
Plans are to pick up some 17" wheels that should work out fine. Was wanting 16" wheels, but can't beat the price. If nothing else, they'll work for mock up. And the tires I pulled from the vette will fit on them.
Had a pretty good Saturday. Went riding on the RK, had lunch at the Fin Inn in Grafton, IL, crossed two rivers on ferries and road back home. Sunday was even better. Got to work on the frame most of the day. Used the new cold chop saw. What a time saver it was. Anyways, here is a pic of the frame work. Squared up and tacked together.
9683
Update: Front steering support is welded up short of the neck tube. Rear framework has been started and will most likely be finished this weekend.
Front frame also helps out as a bench...its flat.
The struts will be attached to the upper rear frame.
​12526
Would like to thank irmagoo for his strut spacer idea. The original strut location would limit me to a 26" tall tire. After spacer, only the width is limiting depending on the backspacing. Thanks again.
Before spacer.
After spacer.
13067
Started the wiring yesterday. One of the steering bearing cups is almost done. And started to prime the frame to help stop the surface rust from forming.
14768
Looks like progress on all fronts.....wiring can be a nice diversion from frame work....it is nice to let unformulated ideas "cook" while working on something that is figured out!
Hahaha, that's a good one LarryA! Don't know if all of the wiring is as figured out as it should be. I had a couple of wires that I mis-labeled "Fuse Block" that went no where near the fuse block. Oh well, live and learn. I have my niece's wedding to go to this weekend so I doubt if I get much done on the wiring or the frame. Will be making her and her new husband a firepit between now and then. Which means I'll also have to get the plasma table fired up and rolling. If it isn't one thing, it's two more.
However, the steering bearing cups are coming along nicely. The GF's machine instructor is letting her use them as a class project for her Mastercam and CNC project.
Lets just say that I learned to look at all things. My GF came out Saturday evening when I was working on the trike and asked where the dipstick was. I looked at her thinking what the hell kind of question that was....I pointed at the front of the engine and said "right there". And then realized that the dipstick and the oil fill hole was under the electrical box. Not a good move on my part, duh!
So spent Sunday through about Tuesday cutting the bad location out and putting the new box in on the front of the framework. Which puts the electrical components right behind the back seat. Bearing cups are done, will start setting the steering neck and stuff in this evening. Then onto the fixing of the inner tie rods, mounting the radiator, and coming up with an exhaust setup. Anyone ever use the 12" bullet mufflers?
​18172
nice layout for electrical in a dedicated area. Mine ended up in about 3 areas.
Understand about location of things only too well.....1st component... no problem, then, compromise on everything else.
But therein is the challenge, and most of the fun!
wire nuts?
​18172
I hope those wire nuts in the lower left side of photo is for mock up?
Currently trying to figure out where to put the battery in relation to the fuel tank and the cables for the motor. As everything gets finalized, the wire nuts will go away. If you look at the earlier pic of the wiring, everything was put together with wire nuts to make sure that everything worked like it was supposed to.
Steering cups welded into the neck, neck welded to the frame. Lined up fairly easy. New inner tie rods installed and fairly aligned. Neck needs a little clean up. Tried a couple of wheel/tires from the GF's grand cherokee on the back of the trike. Went from 7 1/2" of ground clearance in the back to almost 10" and from 9 1/2" in the front to 12" along the front frame. I like the heep tires.
18963
Pic orientation good here. Is the smaller wheel from the 89 olds? At any rate, the Jeep wheel does look good. Wondering about final drive ratio, with the larger wheel? Then again there are 40 and 50 series tires and various wheel offsets to consider. Anyhow an interesting subject!
The small one is a 17x8 rim with a 275/40 tire on it. The heep wheel is a 16x7 with a 245/75 all terrain tire on it.
The original 89 olds rim was a 15x6 with a 215/65R15 on it.
The tripletrees and front forks are going together. Will be doing the leading links later this evening. Corners still need to be chamfered or rounded over and a general cleaning and final shaping. I don't want to spend tons of time on something that gets scrapped so we are in "pre-assembly" mode.
20334
A bit farther ahead. At least it's sitting on three wheels. I won't be using the MC rim/tire combo for anything but rolling in the garage. Still haven't figured out which wheels I want. Not too sure about the vw shocks, I don't think they have stiff enough springs at this point. When my gf and I are on it the shock springs are gapped about an 1/8". Not quite far enough for my liking. There is a FS grain elevator a couple of blocks from the house, may have to take the trike over there to get it weighed after I put some bars and some brakes on it.
Here's a pic of the garage dog...after fighting with the broom, truly a funny sight.
Still need to weld the cross bar for the leading links. Now that the width is set, I can do that.
It may be sitting on three wheels, just not ready to ride.....yet.
21079
Front wheel, 16 x 5.5, finally came in. Correct hub 3 days later. New P235/70R16 All-Terrain tire is mounted.
Fuel tank tigged and in place, not tied down yet. Need one more fitting for the vent line.
​23613
when u get that far .. use round or square tube but not flat bar
Sure will. I have a piece of 1x3 rectangle tube, either 1/8 or 3/16 wall, for that. The round bar that is there won't actually be the front axle. I'll be using a piece of 4130 for it. Didn't want to do things twice, but until I was sure about which direction I wanted to go, I just did the minimum on the front axle and the steering neck rod. Will be making the new parts this week.
KingJuice69
