My Friday ride
Sully
Trike Talk Executive Chef
Gold Member
Mar 23, 2014
27,934
59,799
Kennesaw, GA
Jerry
Well it's Friday again, time to ride. it takes about 2 1/2 hrs and 3 beers to cut the grass. :laugh:
Man, if I had a lawn tractor that looked like that, I would be cutting my grass so often, the ants hiding in it would put out a hit on me for messing with them.
First time I say a similar post I told wife IF we had a yard big enough to need a riding mower I'd to this in a minute! Unfortunately in SoCal property is so expensive you couldn't afford to water the grass, let alone mow it.
What have you done to reduce the heat issues on that rig? Removed cat? Re-tuned? Crotch cooler, lift kit, reversed front tire? Air pressure? Do you wear a helmet? GPS? Better seat? What is MPG numbers? Slip-ons?
Carbon fiber or steel mowing blades?
:clapping::10:
What brand and weight oil do you use....??
I've been trying the new Synthetic 10/30 made from liquefied Squirrel tails.
Geez, you guys crack me up.:laugh: This is a proto type so I don't have all those problems. :xzqxz: Yet :confused:
I like the way you have the tank lifted, does it stop the wind from coming over the tank? If you go into production, I would recommend a chromed wheels option. Most trikes are into chrome...Just my 2cents.:Dorag:
ledgin
