Rmitchell55
850+ Posts
For those of you that have had your motor apart and had put back together there is a mistake in the torquing procedure in the repair manual that if followed will probably result in broken head bolts. A friend of mine that has a small independent shop that works on just about anything has had two oil cooled Harley M-8's in the last couple of months come in leaking oil from the rear head area and on both he has found the head bolt on the rear head by the exhaust port broken. The first bike he repaired by the manual and the customer picked it up and two days later brought it back with the same problem, pulled it apart and found the same bolt broken again. He called S&S and they told him that the manual was wrong and how to correctly torque the head bolts. The second bike he is working on now and I was talking to him today and hew was installing the heads. this bike is a 2019 Street Glide M-8 107 with less that 1000 miles on it and the customer brought it to him leaking oil from the rear cylinder head area. The motor had just been rebuilt and had been sold. The customer had just bought the bike from another person and had no idea what was done to the bike so he also wanted to find out what was in the engine. The cylinders were pretty beaten up so the customer decided to go big,so he is installing as S&S 124 kit on it. It already had a S&S 465 gear driven cam, cam plate and oil pump in it. On page 4-38 of the service manual gives torquing sequence of the head bolt and the last step is to torque it an additional 90 degs. That last step over torques the head bolts and causes the rear one to snap because of heat. S&S says to torque the head bolts to 45 ft- lbs.
