Missing Two Wheels
Jun 2, 2016
68
23
Windham, NH
I had my '04 Gold wing converted to a Motor trike IRS nearly 2 years ago. While I mostly feel safe on the trike, I do miss the two wheels. As I aged I have become more vertically challenged.(shrinkage!) I sometimes think I should have purchased and installed the Low-Wing bracket (www.lowerwingproducts.com) before converting. Does anybody have experience/thoughts with this product? I will appreciate your inputs.
Not sure what you want. You have converted your bike to a trike with IRS... but that bracket is for lowering a stock GoldWing, your trike likely doesn't even use OEM rear spring now. What you think you maybe passed up as an option 2 years ago is kind of mute now.
On a trike, you don't use feet to hold it up anyway. I rarely ever drop feet to ground when on the trike, but I do on the '85 GL1200 bike I kept.
Thank you for your consideration to my question. I guess my post wasn't clear. You are correct that this would be for a stock Gold Wing, not a trike Gold Wing. I would consider purchasing another GW (2 wheels) if the lowering bracket is a safe modification.
Marks2024
