I understand michilin pilot active , rear mount tire on the front of a trike
is the way to go , anybody got any info on this?
I don't think so! the tire will out last the HD
Rally, I don't think MPA makes one the correct size for the HD front wheel (at least that's what a friend found recently when he tried to find one for his RoadGlide trike. You probably have to select a good quality Dunlop rear motorcycle tire the right size and use that. Should give you excellent results with far more mileage than the traditional front tire tread.
Will the MPA tire or similar made by Michelin work on a 2010 FLHXXX H-D?
First, rear versus front. Rear tires are generally stronger and slightly flatter in profile. Note the last two numbers in the designations here, which are the load ratings::Flag:
Can anybody explain why a rear tire, mounted in reverse, on the front of a trike works so well and outperforms a normally mounted front tire?
Thank you.
Ride safe!
Watch out for the idiots!
Mike
:wtg:
