Do you have Love Jugs installed on your motor ? If so, did you install them ? and do they make a difference ?
http://love-jugs.com/
Sorry for the long post. But hopefully my review of the Love Jug Fans will answer most questions riders will have.
Bike week here has ended. I got out the last few days riding with a few buddies from my home state and we rode up and down the Grand Strand in the traffic. I can say from my observation that the Love Jug cooling fans helped keep my 124" oil temps lower by 15 degrees over the HD parade fan I have been running.
After getting caught up in the stop and go traffic after riding for more than 40 minutes the oil temps never got over 240 on a 90 degree day.
I rode one day earlier in the week and after arriving home in my garage, leaving the engine running, I got my infrared thermometer out and checked the head bolt temp without the fans running and saw the temps @ 210 front and 218 rear.
I switched the fans on and waited 5 minutes to check the decrease in temps. The second test with the infrared thermometer the front head showed a 18 degree drop and the rear was 15 degrees. My oil temp ( which the thermometer is located to check the oil temp coming from the Oil Bud oil cooler Im using ) was a steady 225 after 5 minutes down from the 240 when I arrived in the garage
The fans do work. They do blow a large volume of air at each cylinder. They are not noisy and I could not hear them running at all with the engine at idle. The heat could be felt on the right side with the fans on, but it wasn't un-bearable ( too me )
The frame mount that came with the fans I could not use due to the height of my 124" engine. ( 1/2" taller than stock ) Second and I had a discussion with the owner of Love Jugs as to why Im not in agreement with using the Love Jug frame mount. Removing the strap for the stock horn is a bad idea. That strap has a specific purpose. (1) To keep the cylinders from rotating slightly from harmonic forces when the engine is running. ( 2 ) To keep stress off the intake and to keep the intake gaskets from leaking from the slight harmonic movement of the cylinders.
The stock strap with the horn mount works perfect for mounting the Love Jug fan assembly. I did add a thick washer behind the horn bracket to offset the fan assembly outward another 1/4". After doing this, I hit the fan assembly with my hand to simulate shock from the bike and the horn isolator would not allow the fan assembly enough movement to ever come close to hitting the fins on the heads. The fans shake slightly when the engine idles. But they moved less than the horn cover did alone on the same isolator when mounted on the engine.
The stainless used for the Love Jug Fans is top quality and shines like chrome. The lighted switches on the top of the housings are waterproof and are illuminated to let you know the fans have power. The wire harness is top quality. It has a connector to allow you to plug it into the stock HD wire harness for a quick easy connection.
My ideas to make some improvements
1) A thermo switch to run the fans when the head temps get to a point that the fans are really need to be turn on and would allow the fans to run for a few minutes to help cool the heads down quicker after shutting down the engine
2) Make a quick disconnect in the wire harness behind the bracket for easy removal for cleaning and servicing the engine
3) Redesign the frame mount to keep the engine strap in place
4) Offer it in all powder coated black or a combo of black and some polished stainless
In summary, the fans do deliver what is promised for air flow to cool the engine. Obviously for some the size of the fans is a issue, but if you can get passed the size of the fans and want something to help keep the engine temps down and manageable. The Love Jugg fans will do just that
Tom
Very good post Tom. I think the Harmonic forces is a problem I have with the Wards fans? Need to talk to you more about it.
