loose control knobs
The a/c control panel itself is held together by 2 phillips head screws. The main control panel must be pulled away to access them. Once you remove the 2 phillps head screws, the outer cover will come off allowing access to the .050 allen head retaining screws for the knobs.
you know i did take the panel screws out and pulled it part way out with out unhooking all the connections and couldnt see anything like that with the allen head screws. maybe i should have put my glasses on to see better, thanks for the info, be gone a couple of days but when i get back ill take it back apart.
stoney
