Liqui Moly 2024 Synthoil Race Tech GT1 10W-60 Motor Oil
PosseRider
3750+ Posts
Gold Member
Jan 29, 2016
4,164
3,959
Dayton, OH
Bill
:gah: I searched first & see nothing here on this oil. SOOOO had to start an oil thread. sorry:( Has anyone used this oil & thoughts on it.
Produced in Germany and it appears it's a sort of Racing Formula for what they classify as Motor Sport Bikes. Take a look at Liqui Moly's Harley Recommendations for Engine/Gear Oils and Brake Fluids for the Harley 2014-2016 Twin Cam 103's. This Race Tech GT1 Formula is not on their recommended list.
I used this oil on previous bikes. It works great. Quiets the motor down, seems to help keep it cooler. Ran it on a 12 RGU, and a 15 RG. If you want, HTT has a very long thread with good info. A lot of people over there recommend it. I’ll switch over to it at 5k.
Jack, I knew you would jump in here. When will you just admit you like oil threads!:clapping:
Your killing me:p
The post I made is a guy I knew pretty good
He died last year, But we talked alot prior to his death
He did ALL his own wrenching and used REDLINE oils always til 130,000 miles
After the switch he racked up another 50 k with no problems
Pretty impressive miles on a Twin Cam in Arizona heat
Thanks to all who responded, I will check out the HTT forum. Wmitz, let me know when you try. I still have 2 or 3 changes of Mobil 1 before I switch. Witch on did you use?
I used the 10w-60 (2024). The 12 rgu was a noisy engine, after I started using it the engine quieted down considerably, helped to keep it cooler in FL. Basically the same thing for the 15 rg. I’ll use it again without hesitation.
Are you talking the 2024 or the 50wt they have on their site.
Race oil= Race-dump oil- reload.You don't have a race motor.
[h=2]Liqui Moly 2024 Synthoil Race Tech GT1 10W-60 Motor Oil - 5 Liter Jug[/h] Question to LM
Can this be used with a 5000 mile oil change.? The 60w is a preferred oil due to high temperatures in the summer here. Many trips in 90-100 degrees.
Reply from Liquid Moly in Germany.
Dear Bill, yes, because Liqui moly LM2024 is a high performance engine oil and perfect for this 5000 miles oil service interval
With best regards from Germany!
After Four Rivers Harley built my new motor they told me to use Shaeffers Extreme V-Twin Synthetic Plus Racing Oil 20W50 from then on. They custom build motors for customers all over the U.S. and claim to have really good luck with Shaeffers.
I've got 14,000 miles on the new motor and it has done great.
wzejda
