Lets See Some Rear Cylinder Heads
Sep 20, 2009
4,577
299
NE Ohio
Mike
I haven't had a chance to snoop around other Triglides to see if they are exhibiting the same thing as my dads 09 and my former 10 did. Both or our Triglides where tuned on the dyno and running a richer than the lean 14.6 and sometimes higher AFR Harley Davidson delivers them at. I started noticing the powder coat lightening or burning off around the spark plug area including down some on the fins. I'm not sure if this is due to running 8-12 hour days on the freeway at speeds of 75 mph + during the the hot months of summer, or something else. I'm thinking its just plane not getting enough air flow across the rear cylinder while riding at those speeds.
I dont have a picture of the first heads ( sold them ) that I had on my engine for 30k miles, the rear head had no discoloration as the 2 pictures already shown.
I wonder like you, if it is related to the lower front fairings causing a different or lack of airflow at the rear head?? :Shrug::Shrug:
On my Roadglide trike I dont have lower fairings. I do use the vinyl splash guards only when its raining heavy.
I'll double check, but I don't think mine is that bad either. It won't get any worse since I now use Ward's FCS. Same thing in Dennis' picture.
My front looks fine, picture of rear. Not as bad as yours.
20K
Dennis
Yep not quite as bad, the rear head on my 06 Ultra is still like the day I installed them. They have around 26,000 miles on them, most of the miles as a 95" build making 104hp 100ft/lbs torque, I traveled on this bike. It has been to the east coast twice and out west to SD once plus many other shorter trips. I have around 1,800 miles on the 120 now and the head still looks great.
It may be from a combination of the lowers and the big wall created by the rear fenders. The heads on my 06 Ultra which has had lowers on it up until just this year still looks like the day I got them back from the head porter. In all instances the bike was put on the dyno and tuned. I'm even running O2 sensors on it now and it is using closed loop in the cruising areas.
Does the Triglide come with the air baffle under the lower triple tree??
Another question Msoko3 Do you and your dad ride 2 up or mostly solo?? I wonder if having a passenger would also create a different air flow across the rear cylinder??
The Triglide doesn't come with a baffle under the triple tree. My dad rides 90% 2 up and I road maybe 50% 2 up and 90% pulling a trailer.
Looks like you took a picture of my 2009 rear jug Mike. 43k miles. Has looked like that for two years now.
I'm starting to think its the rear cyl not getting enough air flow due to the fenders and box of the trike blocking it.
I notice no mid frame air deflectors? Did you guys remove them or did they not come with them. My 2012 doesn't seem to have them and I realized it as I installed the driver seatback adjust as msocko3 has, but they are shown in all 2012 and 2013 pics on website?
I took the plastic ones off and put on a crotch cooler from Captain Itch.
Don't care for the looks of them and they really didn't do much. I tried them when I 1st got my 10 and removed them right after I got back from my trip. My lower leg burned worse than any other part of me, they couldn't help that.
My dads has never had them on, told the dealer don't bother when it come to putting them on. The dealer has to install them as part of the setup.
After looking at these pictures harder I do believe that the white substance is from the head bolts/head covers the corrosion (Galvonic)that is taking place is causing it the run out of the cylinder heads.
It reminds me of rust on bridges where you see the bolts and nuts at the beam ..
Just my two cents..
Dennis, Have the Capt.Itch coolers scruffed the paint on your side covers at the leading edge ? I put them on a short time ago and have been concerned about that, weather has been ugly, in fact snowing here as I write this, so havent been been able to get miles on.
Rear cylinder head looks good on wifes TG with just under 20,000 miles. Like to think its because of all the mods I did early on.
I see nothing. One would have to look past all the other scratches and dirt on mine!!
32,000 miles and all is well. HD sells a spray for the wrinkle black on the motor, I have it but have not used it yet, $14.95 I think. They say it will make it look like new.
iaff84 when was the last time you changed your spark plugs?
HEE HEE HEE, I wonder who would see how bad the rear one looks. Well inside looks fine and it still fires when told to. Does kinda look bad :Coffee:
I saw it, but didn't want to say anything. Figured it was all that salt on the roads back there:D
iaff84,
Thanks for the pics. The crotch coolers don't seem to interfere at all with the backrest adjustment, but, they don't come down as far on the side as plastic ones. I'm still wondering if it actually would cool better without anything?
"The dealer has to install them as part of the setup."
Ah so....
Since my bike was a rental I'm wondering if they went home with the setup guy?
I would like to try them, but not if I have to pay $75 for something that should have been on there?
BTW, is there a 'notification' for posts updates on threads you are in like in most talk groups?
iaff84,
Ah so....
Kindaold, I have two sets. You can have one for the cost of packing/shipping. PM me your address and a set is yours. You may need to get the bolts. Can't remember if I have all of them or not.
Just my two cents..
Would go along with that except I run the same covers on my 06 Ultra Classic. The heads have 26,000+ miles on them since they where ported at Head Quarters. They have resided on everything from a 95" build making 104hp 100 ft/lbs torque to the present 120 making 125 hp and 138 ft/lbs torque. This bike used to be my primary traveling bike so Its been run at speeds of 80 - 85 mph for hours on end in 95+ degree temps while traveling to South Dakota, its been caught in some nasty traffic jams on hot days. The powder coat looks like the day I bought the heads which where take off from a 06 Fat Boy.
I would agree to a point but not all powder coats are the same...Some will look better than others.depending on there process.. After looking at more of the pictures It still reminds me of how the water displaces in those areas of the heads and corrosion.
Not saying heat would not cause some sort of issues but like I stated I think that unprotected areas of the heads and disimilar metals would cause this condition..
dyno56ca
