Lehman Monarch II rear suspension
Status
Not open for further replies.
Oct 7, 2010
3
Canada
Bette
When riding over an uneven surface the rear tire on my trike either hits the fender or, is lifting off the road and then skidding as it connects again. Any suggestions as to the best rear suspension settings for this trike.
I believe that there is a ring to adjust the spring tension in addition to the preload setting.
I am not very heavy - about 170lbs.
Also any idea on what weight the trike will carry - rider, passenger, luggage.
Thanks for your help.
Hi Bette, and welcome to TrikeTalk. We've got some great folks on here. You should get the answers you need :)
Welcome to TRIKE TALK Bette.I can' help with your problem,but you have come to the rite place. Enjoy and RIDE SAFE
bette - Welcome to the site. First check the air pressures in the rear tires. They should be around 18-22 lbs., overinflated would cause extra bounce. What shocks are on the rear? What bike do you have triked? That will determine the what load you can carry.
Welcome aboard bette. Glad you found us.
Status
mudrock
