Lehman gl1800 trike trunk seal
Oct 11, 2010
117
7
La Vernia, TX
Chuck
Does anyone out there know or have any info on the gasket for the bottom trunk.. its the lehman Monarch 1 2002 year model.
I have tried to get info from Lehman but they are not forthcoming with anything regarding that gasket. I know its probably a car ( door- trunk)gasket *generic of some sort but so far i have not located it anywhere nor has anyone i called ( Lehman folks & lehman shops) seem to be able to give me any info.
Its as if once sold that it as far as this item *** Lower trunk seal** is concerned.
DeerWrangler,
I apologize for the lack of response from Lehman Trikes - that's not the way we like to do business. The trunk seal on the Monarch I is unique to that model. Our recommendation is to use the Monarch II seal p/n CW2535. We use 7 ft on the Monarch II trunks and that amount should work on your trike as well. It is a little thicker than the seal on your trunk so you may have to adjust the latch but this seal should provide a superior seal to the original one. Be sure to clean the surface well before insalling the new seal.
Again, our apologies for the lack of responsiveness.
DeerWrangler,
I HAVE A 06 RENEGADE AND HAVE ALWAYS HAD A PROBLEM WITH WATER IN THE TRUCK. have adjusted the latch but no help. what type of seal would you suggest i try?
The seal for the Renegade door is a CW2536. When you adjust the latch, and you probably already know this, it is a 2 step latch. It should click twice when you latch the door. When you look at the inside of the door are there molded in ribs that make an X pattern? If not - let us know.
dyno56ca
