LED's for headlights and fog lights
rogerm60
30+ Posts
May 30, 2015
32
23
Round Top, TX
Roger
I'm doing a little research on enhancing my headlamps & fog/driving lights with LED's or whatever will provide more lighting on the road and to the sides. I'll be upgrading these lights on a 2015 GL 1800 w/Road Smith conversion. Has anyone done this upgrade? What lights did you use? How difficult are they to replace? Thanks,
I've had customers who really like these. They have them installed for trips to Alaska. The problem with any of them is tucking the add'l wires and their modules in so that they never rub on the forks or triple-tree as they rotates from side to side.
http://www.socalmotogear.com/HONDA-G...M-p/g18h7p.htm
As for fog lamps, I always recommend Hondaline LED fog lamps. They come with Honda quality, and reliability, and you'll be able to adjust them correctly. Many will pay less and get the "exact copies" that look just like the Hondaline ones. However, occasionally I'm not able to align them correctly because they are not really exact copies.
https://www.partzilla.com/product/honda/08A00-MCA-W20
I replaced the 55 Watt H3 Halogen Bulbs with 50 Watt, High Performance, H3 LED 360 Bulbs in the Spotlights on my Valkyrie. I used Pathfinder Part No. 226-0003 -Pure White -6000K.
All I can say is WOW! They are great. It’s my intention to replace the Head Light Bulb with Pathfinder LED 4H 6000K Bright White Bulb.
Check with Kevin from DK Custom, 1 of our sponsors, & see if he has a replacement bulb that will work.
I want to be seen. I have replaced all the bulbs in the rear with Pathfinder LEDS. I have the Honda Spoiler with the Electrical Connection 4 way kit. Muth mirrors. Pathfinder Turn Signals/Driving Lights on the front side of the mirrors and Pathfinder LED low beam headlights. When I ordered the Trike from the Honda dealer I had them install the Honda LED foglights.
jhlesher
