Leak? On board compressor/air suspension
Jan 3, 2009
1,879
62
United States
Dave
My MT conversion has an on board air compressor for my air ride suspension. There's not much difference between it and the factory HD air shocks in principle or theory. Other brands of bikes and trikes with air ride suspension would be the same. This is why I am posting in the general section.
I have noticed that each time I hop on that the air pressure gauge on the dash shows a smaller amount of pressure than I left it. For instance, I ride with 40 pounds on the gauge but if I wait a few days to hop back on it will show 35.
Experience with touring bikes was little or no loss of air pressure and I would check the pressure with the HD pump every few weeks during the riding season and hardly ever had to pump it up.
Question... Does anyone else experience this? Do you loose a small amount of pressure or none at all through a season of riding?
I took the front faring off yesterday, pumped the system up to 60 and soaped all the connections behind there. Nothing.. I had already soaped all the connections on the shocks and the tee connection and air compressor. Still nothing.. After putting everything back together I noticed the gauge read 55. Does anyone know if there have been issues with the pump leaking through or other issues I should check?
Any comments?
reksul, Stallions have the same issue. It appears the newer ones the issue is resolved. They were using a check valve that was not getting the job done. I told that they have changed that valve. Being that MT conversion is the same company as Stallion I would check the check valve. Check with Russel at Thoroughbred Motor Sports of Daytona he is the one who advised me of this issue. My wife's old Stallion would not hold air in the bags, her replacement Stallion does not have this issue. Ted
At least on the Stallion there is a check valve on the aluminum distribution block. I'm not sure about the MT conversion but I'm sure there is something similar.
dhinzman1
