Larger Wheels on Voyager
Jul 18, 2014
10
1
Oscoda, MI USA
Brand new here an just purchased a used (brand and model exact) standard Voyager kit for my Aero.
Has anyone ever switched Voyager wheels from the standard 13" to larger. Very happy with my buy price and quality wise. Just wonder how big a task it is to do the wheel switch.
How much fender clearance do you have? Finding the right bolt pattern wheels and then mounting tires on them. .
Unit not here yet. Being shipped. I'd say 2-3 inch clearance is there. Might also be able to raise fenders if necessary. Was mainly hoping it was a wheel swap as you say and not a full hub change. Looks like the kit wheel specs are GM 100mm 5 lug.
Y R you thinking the Voyager wheels should be larger. Mine were plenty big enough.
they are not low profile they are good size tires.rims are 13" not tires.
John,
Good point. Not sure I'll do the swap, but the current original 13's have a fair amount of surface rust. Unless they'll clean clean up nicely, I'll at least want new rims. If no real advantage to have larger, I'll stay with 13's.
AnjaRatcli
