Khrome Werks narrow 2+2 sweeper bars on a 2021 FLRT
Nov 21, 2021
9
3
Prescott
Ralph
Has anyone added the KW 2+2 narrow sweeper bar on a 2021 FLRT? What bar did you use, ie. #300518?
Did you have to extend cables? Did you run the throttle cable outside? What did the conversion cost?
I'm 5'9", have 33/34" sleeve length and experience middle of the back and neck pain with the OEM bars. I've tried to lower them in all practical positions.
Thanks for any input you may have.....
Hey ..Ralph I can't help on the bars.....But i will Welcome You To Trike-Talk...:wave4::wave4:,..
Hi Ralph. Welcome. There is a current thread about this install on the Tri Glide section of this forum.
Khrome Werks 2+2 narrow sweepers 300519
Not sure if your Free Wheeler has the same clutch and front brake hoses. I'd check that out and if it does then I think the KW narrow 2+2 would fit just fine. I have them on my 2020 TG and really like them. You have plenty of wire to run the throttle wires internally. Takes a little effort t pull them through but not all that big a deal. Look at some You Tube videos to get some ideas of best way to pull the wires.
Good luck with you install.
shawn.s.prescher
