Khrome Werks 2+2 Wide Sweepers
May 22, 2016
45
10
West Coast BC Canada
Today I installed heated grips on my 2018 Tri Glide, and I also intend on installing KW 2+2 Wide Sweepers in the fall. Installing the heated grips allowed me to see what I was up against when I install the new bars. I feel there is enough slack in the control wires - I will get the extension for ease of installation. My question is the brake and clutch lines - could not see enough slack to go up 2" and back 2" plus the extra bar width. Any experience with this install re/clutch and brake lines would be appreciated.
Ron
Had my dealer install mine, they did use extension wires but did not need to extend the clutch or brake lines.
Bob
Odered mine today after reading all the rave reviews decided to make the leap!
I have mine but not installed as yet. As stated on the earlier post I put heated grips on so I had a dry run. I did buy the wire extension just in case, as I am a long way from a dealer and did not want any surprises! I also examined the brake and clutch lines and will be able to gain a few inches, if needed, by having the radio cable on the outside of the brake and cable lines. Weather is changing for the better here so might be a fall/winter job. Good luck with your install.
Ron
Ron
Thanks, Im hoping I wont need the extensions, Ive seen a video where they realeased the wires from their perch and gained some length.🤞🙏🏻
I believe Bronxbill installed 2+2 wide sweepers on a 17' he extended the wires just to make sure nothing was stressed. I did my 09 four years ago. DSC00124.JPG
I did mine on a 2016. If you search under the fairing, you will find a lot of extra length hoses and cables wire tied near the radio. If you cut the wire ties there is plenty of length. I did use the wire extensions, cost me $25 from Boardtracker
Sorry Bill wrong year my how time flies... Fred
Ron A
