J&S motorcycle jack for a Freewheeler?
Apr 20, 2011
68
37
Ardsley , N.Y.
Hello All
Was wondering if anyone has used a J&S standard motorcycle jack
to lift a Freewheeler? I have messaged J&S about this and am awaiting a reply.
I would only lift just long enough to reposition in the garage and keep it
VERY close to the ground
Thanks very much :)
Dante
Hello All
Thanks very much :)
Dante
If thats all you need, just get 2 car dollies & a motorcycle dolly for the front.
You can usually find used one's pretty cheap compared to new.
The JACK
Hello All
Thanks very much :)
Dante[/QUOTE]
I use a Harbor Freight jack that I upgraded the hand pump portion of jack to 1.0 ton. Got pump at Harbor Freight then for around 20.00.Most motorcycle jack stands are made quite sturdy,but the pumps they put on them determine the lift capacities. Freewheeler would need at least a pump jack rated at 3/4 of a ton at minimum.
I believe...
Gerald ,the J&S Jack has a 6 ton bottle jack and can lift 2000lbs. I'm sure the capacity is there...it's the
shape of the underside of the trike I'm concerned about. :confused:
I suspect I will put up the J&S for sale and use car dollies instead.
I will wait & see what J&S says
Thanks all!
Dante
According to a chart on the web sight. For trikes:
Yes w/ Trike Lift – HD Tri Glide and HD Freewheeler
*No Conversion Trikes*
Must be the trike jack.
Right answer, J & S two wheel jack is different than the TriGlide or Freewheeler jack per their web site. Not a cheap jack to buy.
It would have been nice of J+S to have a conversion kit for sale for those of us with the two wheel jack. I know, profit....money, money money. But gosh to spend $700 twice is just plain asking too much. Besides I have more chrome to buy dang it! :xzqxz:
J & S Trike Jack - heads up info!
Just for everyone's information....I actually purchased the Trike Jack thinking it would work perfectly for my 2017 Freewheeler. I did so, because I really liked the 2-wheel J & S Jack I bought previously when I owned my Softail Deluxe (awesome jack).
But now the sad news...…..The Trike Jack did not work with my new 2017 Freewheeler! :mad::mad::mad: The cradle piece that elevates so that it misses hitting the emergency brake didn't clear the brake, and appeared to hit other components like exhaust crossover pipes. It was even to tight up against the fender when trying to jack it up. So, after repeatedly trying to get the J & S folks to return my calls, I had no other choice than to send the jack back to them (at my expense-which wasn't cheap) DO NOT BUY THIS J & S JACK for a Freewheeler! :nonono::furious::ranting:
J&S jack is crap. Had a piece break on my jack only after using twice, I emailed and called repeatedly, no answer. Finally had do my own research for the part. First and last time I will buy from them!
Boatpaddle
