Is this the same as Oberon?
I also use the Oberon, both clutch and brake. I don’t think my hands are that small but with the stock clutch I could hardly reach. I have it set to 1 and have no problems starting it. I only got the brake lever so they’d match.
I bought the clutch only and as I have Get a Grip magnum grips installed the lever will only work right in position 3 it will not start in gear in position 2 and will also stall for some reason. I will be taking it of to see if it is possible to remove some material from the lever to let the neutral switch come out further so I can keep the lever at the 2 position which I like. I also like the Get A Grip grips.
I installed the clutch lever today, got it on with no issues, problem is no start in gear.
The switch button is coming all the way out as far as I can see. Possibly the switch is defective?
Nice have the clutch grab somewhat close to the grip like it should.
Now you have Large Grips if that's what I'm led to believe. I have Large grips also, and having trouble starting in gear. I have stock levers. So if I changed to smaller grips, the starting in gear might get better? I've heard something like that before. Thanks.
Jerry
shawn.s.prescher
