Yes, And thats what i'm using, ...
I bought the clutch only and as I have Get a Grip magnum grips installed the lever will only work right in position 3 it will not start in gear in position 2 and will also stall for some reason. I will be taking it of to see if it is possible to remove some material from the lever to let the neutral switch come out further so I can keep the lever at the 2 position which I like. I also like the Get A Grip grips.
