install marlin's oil/cht gage .? in ign feed
May 8, 2011
755
21
Peru, IN
Leon
i am installing a marlin's oil gage in a '09 tri-glide. where can i splice into the ignition switch for power. under the ft. fairing. thanks.lb
TIPS: when doing the rough install on the oil temp gage,
1. put a light coat of RTV on your left hand (fingerprint area). this will hold the washers etc in place as you reach into the gage area to put the washer on the stud..
2. do the one nearest you but leave it slightly loose. this will allow you to rotate the gage so you can put the other nust & bolts on.
3. rotate the gage so that it is straight up. use a 2foot 1/4 " extension with a universal
on the end; and a 3/8" 1/4" socket.(typically).
4. if you have to reach into the area to install the final nuts;as before put skim coat of RTV on left hand (fingerprint area) reach in and hold the nuton the threaded stud;
then trach in with your right hand index finger (longest one) and as you hold the nut,
spin the nut with your right hand clockwise. this will start the nut.
5.it also will help if you go to the hardware store and purchase 4 nylon locknuts;
as they are thicker and easier to work with. the thin brass nuts go onthe inside and the
nylon nuts go on last.
6.you will also need 18 gage wire, along with 3 eyelit terminals; maybe 3 male .
the instructions call them blase terminals. ane 3 female terminals. All this doesn't come with the gage kit.
as far a where to hook up th wires to. i used the existing orange wire for the oil gage lighting. (i made a wire 4" long with a blade terminal on one end and a female end on the other. this allowes me to hook the wire into the existing wireing harness.
7. the only time i had to strip a harness wire was on the cigarette (orange) power wire. to hook up and give power to the (i) IGN side of the gages terminal.
8. i also went to RADIO-SHACK and purchased the silver oxide based grease.$10.00
9. when you take out the head bolt Ft head nearest the horn. it is easier if you have a 9/16 drop-down wrench. but not necessary. USE a piece of emery cloth to roughen up the cylinderhead contact area on the brace for the cylinderhead temperature sensor. and the bolts washer. I also used the gringers wire brush for this.
hope this helps.i hope it works, and lastly other guys may have a better info as to where to hook up the wireing. lb
this will ensure good conductivity along with the grease.
10 when you splice into a existing wire, soder the wire, then coat it with RTV sealant. and wrap with elec tape.
11. to keep the elec tape from unraveling after you finished twisting on the elec tape ; take a 1"piece of elec tape
and fold it over the wraped tape end and let both ends come together.
12 the male eyelits that go over the blade terminal come in two sizes. make sure you buy the wider ones.
I normally use the wires and power from the air temp gauge power connector when I install oil temp gauges, never had to hook anything to a head.
whever you splice into a existing wire; soder ir then put a light coat of RTV sealant over the spliced area. that will seal it from weather,let it dry/ or use hair dryer; then wrap
with elec. tape.
the marlin oil/cylinder head temp gage goes there. a toggle switch controls which it senses. can use only 18 gage wire because the toggle sw. eyelit holes is 18 gage. thanks leonhad a #8 chrome h-d ground bolt left over.
guess i've got all winter to think that one over.
mark1161
