Heated Grip wiring connections for 2020 Freewheeler
pigfoot63
70+ Posts
Gold Member
Sep 22, 2020
97
158
Gainesville, GA
Roy
Are the 2020 model Freewheelers pre- wired for heated grips.
I was looking today and found the wiring connection for the throttle side
but could not find the power supply wiring.
Here's the thread from when I installed mine. You have the buy a wiring extension to run the power wire up to the front of the bike.
Thank you Sir, I kinda figured using the wiring extension was the way to go. That will give me
a place to charge my phone as well. Really wish they they had the put the power supply wire in the
harness like on the touring models.
Order the accessory wiring harness from Namz and the Trike manual from Surdyke , glad I am not in a hurry as both advise extended shipping times.
Got my Namz harness installed, got more connections now than I will ever use. I have my Love Jugs wired to my DLC under the left cover. I now have six more with the install of harness.
Four of these are switched power and two are constant. I left the fuse out of the constant power as of now
I have no use for constant power.
Thanks to all who responded.
dyno56ca
