Good evening
Has anyone changed there headlight bulb out for a led bulb, pros, cons?
also I have read where other members have made both headlights on at the same time.
are both high and low beams on the same focal length. what I mean does the projection
of the high beam have a different pattern than the low beam. also I was wondering
when you turn the key on the headlight comes on at a lower voltage, and then when
you turn on the light switch it is 12v, is the relay involved one that lets a certain amount of voltage through on one setting and then when activated it goes to full12v.![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I would like to have both lights on together and I plan on making them leds. before I get too crazy I would like to hear from others who have done this.
Thanx
Dragon
Thanx
Dragon
