header too long
May 13, 2018
101
99
Princeton, WV
David
bought header pipe off e bay with cat removed several months ago. decided to put it on .to long y pipe clamp wont fit . pipe was cut in middle to remove cat , welded back weld makes it 1/4 longer than stock.
Take yours use a cut off wheel cut a door opening in it like 3" wide chop out the cat, its a bitch to get out, weld it back together or have it welded maybe take 1 hour to do . no need to cut the pipe in half .
If you are talking about where the header makes a left turn to connect to the crossover...have you tried loosening the bolt that holds the crossover in place against the trans? If it is only 1/4" off, you can then use a washer as a spacer (if needed) on the crossover bracket, and your left slip-on has plenty of play, forward & backward, so that is a non-issue.
If I am understanding wrong, post up a photo of where you are having a fitment challenge.
header to long
tried that and it worked thanks for your help
dyno56ca
