HD Stock Oil Cooler
Jul 17, 2011
34
Oconomowoc, Wi
Does anyone know how good the Harley stock oil cooler off a 2010 TG is?
Are the after markets, like the jagg 10 row, cool better and if so how
much more would they lower your oil temps.
thanks
Dan
thanks
Dan
I have used the Jaggs on all my bikes, they are better than the current HD oil coolers.
Right now I am looking at the fan assisted 10 row Jagg or the Ultra Cooler for my 2011 Tri Glide.
My dad was seeing 290 - 300 degree oil temps when his 09 Triglide was stock. Switched to the Jagg 10 row and tuned it. Now oil temps run 230 - 240 depending on how hot it's out side and the load on the engine, my 2010 runs the same temps.
Most seem to be using the fairing mount - which should have been there as a stock unit, IMHO! I've been told the "dipstick thingie" is not accurate. ;)
i have the dipstick thingie.checked it against a good digital thermomenter in boiling water and it was about 3 degrees higher.212 to 215.seems close enuff.
I have JES dipstick with a oil filled dial thermometer on in and the temp gauge in the dash with the sending unitl at the output side of the oil cooler. I see a 35-40 degree difference. I use a Oilbud oil cooler on my trike. Crusing in 100 degree temps I see 200-210 on my dash gauge
<div class="bbcode_quote">
<div class="quote_container">
<div class="bbcode_postedby">
<img src="images/misc/quote_icon.png" alt="Quote" /> Originally Posted by <strong>FLTR2008TRIKE</strong>
<a href="showthread.php?p=73827#post73827" rel="nofollow"><img class="inlineimg" src="images/buttons/viewpost-right.png" alt="View Post" /></a>
</div>
<div class="message">I have JES dipstick with a oil filled dial thermometer on in and the temp gauge in the dash with the sending unitl at the output side of the oil cooler. I see a 35-40 degree difference. I use a Oilbud oil cooler on my trike. Crusing in 100 degree temps I see 200-210 on my dash gauge</div>
</div>
</div>
</div><br />
So which one is reading the highest?
The HD VROD has a built in oil cooler. I usually run 180 to 190' With these 100'+ days in TEXAS temps have gone as high as 200'. I tried Royal Purple water wetter last week. I noticed 0' difference only $15.00 poorer. curley
so your thinking that the 10 Jagg oil cooler would cool better than the stock HD cooler?
I woild like to drop another 10 degrees if possible.
I'm running around 230 on 75 to 80 degree weather, goes up to 240/250 on 90 plus
days. would really like to get her running at a steady 220, put don't think that's possible.
is the Jagg 10 row worth the cost or should I just stay with the stock HD cooler.
thanks
thanks
IMHO the 10 row Jagg is worth the money.That is what I put on my 09 TG and I am very happy with it.
That is some good news! Seems like your dad was experiencing close to what I am and got it resolved with the bigger cooler and a tune.
Thanks!
I think I'm going with the 10 row Jagg cooler, it's got to cool better than the stock HD
cooler, it's bigger 10 row verus 6 row. At least I hope it cools better.
Ron A
