Harley Logo illuminated on ground
Sep 2, 2013
203
50
Monroe, OH
Mike
11745720_10207403710953533_3557491919113685242_n.jpg11745691_10207403711673551_6677705033932397894_n.jpg 11800508_10207403711193539_1261317153957253906_n.jpg
I just added some Harley Logo lights to my trike to light up the ground in front of my rear tires. Just added the logos with some of the different colors showing on my trike.
I bought them from Headlight Revolution for $72 a pair. I had some Stainless L brackets made and used 3M double stick tape and attached them to the inside of my rear fenders. It confuses people when they see them because the logo actually looks like it is projecting one side under the tire. I had looked at a lot of logo lights and found these which use a cree led which are a high quality led.
I bought them from Headlight Revolution for $72 a pair. I had some Stainless L brackets made and used 3M double stick tape and attached them to the inside of my rear fenders. It confuses people when they see them because the log actually looks like it is projecting one side under the tire. I had looked at a lot of logo lights and found these which use a cree led which are a high quality led.
Thanks guys. Not sure I'll do it...I've never run any highlight lights on any bike, nor felt the urge to. But those things are just so cool I might do it. :)
The logo lights only come in one set off colors, orange and black with white letters. My leds change colors which make the logo lights look different depending on background colors.
Far as wiring I have my leds connected to a switch that is hot all the time. I tapped into that switch so I can have the lights on without needing the trike to be in accessory mode.
Would you happen to have a picture of the bracket you had made?
No pics but it is a simple piece of metal that was bent 90 degrees to make an "L" The top of the bracket is about 1" above the light housing and the Width is about 1/4" wider on each side than the light housing. I spray painted it black and used 3M double stick tape to hold it in place. It is in the center of the inside of the front edge of the rear fender about 2" up from the bottom of the fenders edge.
jkittoe48
