harley front wheel rotor question
Jul 22, 2013
123
63
Patrick, SC
Butch
Hi, are rotors for a harley 16 inch wheel the same. I need a rotor for a 06 16 inch harley wheel so i can mock up brakes for my leading link im building.. I looked on ebay and there are so many and all look like any 5 bolt rotor will fit the wheel. Please keep in mind that i am fabricating caliper mounts so im thinking diameter is not a factor as long as it fits the rim. thanks in advance
The rotors on the 14 and newer are different on touring models, the 08 to 13 are the same but list a left and right. 00 to 07 are the same but the same thing separate left and right. Hope this helps. I looked the part number up on line to get the years.
Non Genuine
Be careful of non genuine wheels.
I've got a fantastic billet front wheel, which came with the bike, but after scratching my head and replacing disks I finally came to the conclusion that one side of my hub was out of true which was giving me a warped disk sensation. Ended up taking that side disk off and converting the front brake to single disk. Now I can brake hard without the sensation that ABS gives you when your on the limit.
I don't have ABS.
Steve
FlintM
