Grease
Oct 10, 2013
176
15
Harrison, OH
John
Have a 02 Wing with 05 Monnarch II kit, How many grease fittings need attenetion and how often?..Thought Ive read every 3000 miles? And just peeking under Trike without jacking up I only see one fitting rear of drive shaft at U- Joint. Thanks for any info. Dogman513
I have an 07 Monarch II and I was told usually give it a couple shots of grease every time I change the oil unless I drive a lot of gravel roads. The only fitting you should have is on the u-joint right ahead of the differential.
Ok thanks Mick, just with my quick look it is the only one I saw. Appreciate it, and Cmon Spring!!
Just looked under my 2012 Monarch II and found no grease fitting. Looked around drive shaft, u joints, and any where else I could think of.
Just bought it so new to trikes. It is a K002144 kit so any help is appreciated.
In the u-joint right ahead of the differential is a zierk fitting for grease. If you run your fingers around the u-joint youll be able to feel it easier than seeing it. To grease mine I back it up on ramps to get underneath it,then I can see it to grease it.
Similar threads
MelT
