Got an electrical question that has nothing to do with Trikes
Jun 15, 2013
9,401
9,920
Red Banks, MS
I have a fan and vent that operate off the same switch. Right now when the switch activates it sends 110 volts to both the vent and the fan.
I would like to have the fan receive power at least 10 seconds after the vent receives power.
This is a 110 volt system and the fan is a bit less than 5 amps.
Ideally I would like to hard wire some sort of delay circuit/relay (I don't know the proper terminology) in between the power source and the fan.
I have searched google and am having trouble finding such an animal...I see a lot of delay circuits, but the all seem to have 11 pin connectors. I just need a connection for the hot, ground and neutral going in and the same coming out.
Any help on what I can purchase, and where, would be greatly appreciated.
Thank you in advance for any assistance.
Good Morning Kevin. You could use this delay control to activate a relay strong enough to feed fan motor power. It appears the device only opens/closes connection to one wire but that will do the job. Your relay should not draw anywhere near the 1.5 amp delay circuit output limit. Good luck with the project. :xszpv: :xszpv:
Here is the link.... http://www.supplyhouse.com/ICM-Contr...FYkCaQodZhAMSQ
This device is used for $20 (new it's over $200) from ebay. It's all in one rated at 10 amps a/c so should also do the job.
http://www.ebay.com/itm/AGASTAT-TIME...zIWbJ3CDB7Thxg
Thank you! ThumbUp
I ordered the "all in one" unit off ebay.
Should work well with the fan/vent combo in the greenhouse. The fan is so strong that it makes the vent work overly hard to open. Now the vent will be all the way open before the fan kicks on.
I said this was not Trike related, but it really is...in a round about way.
Mary grows a lot of our food in her garden. However, we are usually on bike trips during the prime growing season, which has been frustrating for her, and limited what she could grow.
So we set up a greenhouse so she can grow our food year round.
This is a pic of the outside, 1 week after she first planted in it. Taken on January 22nd-
This is a couple of weeks after this first use, taken on February 2nd. In the teens outside!
Photo taken today, March 3rd.
Thank you for the assist!
Kevin, what happened to all the produce in the other container? It was full about a month ago when I was there. Y'all been chowing down on some greens?
Jurgen0419
