Gear Issues with an '09 GW Trike w/ CSC
Mar 14, 2011
51
Durham, NC USA
Travelling to an event today and the Wing suddenly wouldn't shift. Was at a stop light and although it would 'click' into gear... it acted like it was in neutral when applying the gas... and you could hear a slight 'whirling' .... like nothing was making contact in the rear. No prior indications..... Trike Conversion is a CSC....6600 miles.
:Shrug:
Doesn't sound like fun and sorry to hear about this........it could be a number of things from insufficient fluid levels to clutch related problems.
You might check the primary/gearbox fluid level first.......
Clutch might be out of adjustment and not releasing....possible clutch pressure plate problems.......shifter linkage might be loose or damaged......more of a stretch might be bearing issues, drive shaft or rear differential issues.......
Sorry I can't be of more help, but these are a few trouble shooting items.....I'm sure these folks will help you sort it out. Good luck and Ride Safe........
I wish you luck. I've seen pictures of those poor things in lots and lots of pieces when the transmission goes south and they have to pull the engine and split the cases.
:Shrug:
93TrikeWinger,
Is there a grinding noise coming from the right rear just forward of the right rear wheel?
If so it's the drive shaft.
I have read there are some issues with drive shaft rounding on some CSC, I cannot confirm there is an issue with them but, its under warranty, call CSC and keep us informed! Sorry to hear of the problem
Stitch61
